PWM test sketch for Arduino UNO?
General Electronics chit chat
I am hoping Amedee can share the UNO sketch and breadboard layout so I can test the new fans I bought.
If they work in this setup, I can consider putting them in my UMO
(reference: viewtopic.php?f=7&t=74&start=45#p859)
Re: PWM test sketch for Arduino UNO?
You have some transistor in house?
I might! I have all the contents of the Sparkfun Inventor's Kit and a few odds and ends :)
If you can give me the reference of what you have and also the Amp rating of your fan, I can check if it will work and which resistor we need...
You probably need a flyback diode as well (1N400x or whatever) unless the transistor has one builtin.
You are all set ;)
So you need something like this:
For the transistor & diode, use what you have.
For the resistor, to be safe use 2 330 Ohms in series.
That gives us on the breadboard
Now, be careful with the transistor, you need the minus on the emitter and the fan/diode on the collector side (I find the drawing confusing)
Batteries are your 12V battery
Sketch in next episode ;)
Can the USB provide enough power?
Here it is...
  PWM Fan Test
  Arduino Pin assignement
//  Digital
const int usbSerialRxPin     = 0;    // Reserved
const int usbSerialTxPin     = 1;    // Reserved
const int fanPin             = 3;   // Fan control (pwm)
  Globals
uint8_t fanSpeed = 0;    // Start as ...
  Setup routine
void setup() {
  // Serial
  Serial.begin(9600);
  // Fan pin setup
  pinMode(fanPin, OUTPUT);
  analogWrite(fanPin, fanSpeed);
  Serial.println("Setup done");
  Serial.println("Enter desired fan speed (0-100%)");
  Main loop
void loop() {
  // Check input
  if (Serial.available()) {
    long i = Serial.parseInt();
    if (i < 0 || i > 100) {
      Serial.println("Invalid input");
    } else {
      Serial.print("Setting fan to ");
      Serial.print(i);
      Serial.println("%");
      fanSpeed = 255 * i / 100;
Note that all this is untested ;)
LePaul wrote:Can the USB provide enough power?
USB powers the Arduino.
You should power the fan separately (I remember I saw A 12v battery in one of your pictures)
Oh yes have many of those
Return to “General Electronics Discussion”
