UMO / UMO+ Firmware
Topics related to printer firmware
Re: UMO / UMO+ Firmware
Post by Neotko » December 16th, 2016, 6:04 pm
You builders rocks. Btw can someone save that hash yo 'save' the settings?
Post by LePaul » December 16th, 2016, 10:57 pm
I love your firmware! It made my UMO usable with the dual fans!
Post by Amedee » December 17th, 2016, 4:09 am
Neotko wrote:Btw can someone save that hash yo 'save' the settings?
It has always been there -- here is the story behind the hash:
When you build a firmware the MD5 hash is computed on the host which builds it. It is then displayed in your browser:
MD5 from the server
As we have a secure connection (https), there is a guarantee that the hash you see in your browser is the one generated by the builder.
Then once you have downloaded the file you can check on your local system that the file has not been damaged in the transfer by running md5 on your computer. As the whole session with the builder is encrypted, it is very unlikely that something happens, but you never know: you may have an incomplete transfer or whatever.
On Linux or Mac you can run md5sum / md5 on the command line:
Local MD5
I am not a Windows person, so I can't advise but there are various utilities for performing MD5 checks (fciv, certutil from the command line as well as some GUI tools)
Now this 128 bits checksum also uniquely identifies a firmware, as the probability to have the same checksum is close to 2^128 so about zero for this purpose. This is why I am logging the build MD5, that way from a firmware file I can go back and find the build properties.
That's the all story!
Two remarks though:
- For the tech-savvy people, I appreciate that MD5 checksums are no more 'cryptographically safe' these days, it would be possible to craft a firmware file having the same signature as another. Although I could (and I probably will) use SHA-2, it is not really relevant for this purpose.
- For the creative people who will asks: "can I use this checksum to retrieve my builder settings?", the answer is no.
It is just a log file, not a database. And even if it would be in a database, I have not designed the builder to support this. The data structure used to pass parameter between the WebApp in the browser and the backend builder changes as I introduce new features so it wouldn't be sustainable.
Phil.
Post by Neotko » December 17th, 2016, 4:57 am
Sure I know the has was there. Sorry. I mean. Could we use that hash or other generated number sequence to make the builder show the options used?
Isn't really useful now that I think of it aince most people juat have one machine and it won't be much useful to build it again later on.
Post by Amedee » December 17th, 2016, 6:40 am
TL;DR...
This is answered in the last paragraph ;)
Phil.
antiklesys
Post by antiklesys » December 17th, 2016, 6:50 am
Going back to bed leveling, so this is the piece of code that has to be adjusted and added there I suppose....
Code: Select all
#include <avr/pgmspace.h>
#include "Configuration.h"
#ifdef ENABLE_ULTILCD2
#include "Marlin.h"
#include "cardreader.h"//This code uses the card.longFilename as buffer to store data, to save memory.
#include "temperature.h"
#include "ConfigurationStore.h"
#include "UltiLCD2.h"
#include "UltiLCD2_hi_lib.h"
#include "UltiLCD2_menu_material.h"
#include "UltiLCD2_menu_first_run.h"
#include "UltiLCD2_menu_print.h"
#define BED_CENTER_ADJUST_X (X_MAX_POS/2)
#define BED_CENTER_ADJUST_Y ((int)Y_MAX_LENGTH - 10)
#define BED_LEFT_ADJUST_X 10
#define BED_LEFT_ADJUST_Y 20
#define BED_RIGHT_ADJUST_X (X_MAX_POS - 10)
#define BED_RIGHT_ADJUST_Y 20
static void lcd_menu_first_run_init_2();
static void lcd_menu_first_run_init_3();
static void lcd_menu_first_run_bed_level_center_adjust();
static void lcd_menu_first_run_bed_level_left_adjust();
static void lcd_menu_first_run_bed_level_right_adjust();
static void lcd_menu_first_run_bed_level_paper();
static void lcd_menu_first_run_bed_level_paper_center();
static void lcd_menu_first_run_bed_level_paper_left();
static void lcd_menu_first_run_bed_level_paper_right();
static void lcd_menu_first_run_material_load();
static void lcd_menu_first_run_material_select_1();
static void lcd_menu_first_run_material_select_material();
static void lcd_menu_first_run_material_select_confirm_material();
static void lcd_menu_first_run_material_select_2();
static void lcd_menu_first_run_material_load_heatup();
static void lcd_menu_first_run_material_load_insert();
static void lcd_menu_first_run_material_load_forward();
static void lcd_menu_first_run_material_load_wait();
static void lcd_menu_first_run_print_1();
static void lcd_menu_first_run_print_card_detect();
#define DRAW_PROGRESS_NR_IF_NOT_DONE(nr) do { if (!IS_FIRST_RUN_DONE()) { lcd_lib_draw_stringP((nr < 10) ? 100 : 94, 0, PSTR( #nr "/21")); } } while(0)
#define DRAW_PROGRESS_NR(nr) do { lcd_lib_draw_stringP((nr < 10) ? 100 : 94, 0, PSTR( #nr "/21")); } while(0)
#define CLEAR_PROGRESS_NR(nr) do { lcd_lib_clear_stringP((nr < 10) ? 100 : 94, 0, PSTR( #nr "/21")); } while(0)
//Run the first time you start-up the machine or after a factory reset.
void lcd_menu_first_run_init()
    SELECT_MAIN_MENU_ITEM(0);
    lcd_info_screen(lcd_menu_first_run_init_2, NULL, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR_IF_NOT_DONE(1);
    lcd_lib_draw_string_centerP(10, PSTR("Welcome to the first"));
    lcd_lib_draw_string_centerP(20, PSTR("startup of your"));
    lcd_lib_draw_string_centerP(30, PSTR("Ultimaker! Press the"));
    lcd_lib_draw_string_centerP(40, PSTR("button to continue"));
    lcd_lib_update_screen();
static void homeAndParkHeadForCenterAdjustment2()
    add_homeing[Z_AXIS] = 0;
    enquecommand_P(PSTR("G28 Z0 X0 Y0"));
    char buffer[32];
    sprintf_P(buffer, PSTR("G1 F%i Z%i X%i Y%i"), int(homing_feedrate[0]), 35, X_MAX_LENGTH/2, BED_CENTER_ADJUST_Y);
    enquecommand(buffer);
//Started bed leveling from the calibration menu
void lcd_menu_first_run_start_bed_leveling()
    lcd_question_screen(lcd_menu_first_run_bed_level_center_adjust, homeAndParkHeadForCenterAdjustment2, PSTR("CONTINUE"), lcd_menu_main, NULL, PSTR("CANCEL"));
    lcd_lib_draw_string_centerP(10, PSTR("I will guide you"));
    lcd_lib_draw_string_centerP(20, PSTR("through the process"));
    lcd_lib_draw_string_centerP(30, PSTR("of adjusting your"));
    lcd_lib_draw_string_centerP(40, PSTR("buildplate."));
static void homeAndRaiseBed()
    enquecommand_P(PSTR("G28 Z0"));
    char buffer[32];
    sprintf_P(buffer, PSTR("G1 F%i Z%i"), int(homing_feedrate[0]), 35);
    lcd_info_screen(lcd_menu_first_run_init_3, homeAndRaiseBed, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR_IF_NOT_DONE(2);
    lcd_lib_draw_string_centerP(10, PSTR("Because this is the"));
    lcd_lib_draw_string_centerP(20, PSTR("first startup I will"));
    lcd_lib_draw_string_centerP(30, PSTR("walk you through"));
    lcd_lib_draw_string_centerP(40, PSTR("a first run wizard."));
static void homeAndParkHeadForCenterAdjustment()
    enquecommand_P(PSTR("G28 X0 Y0"));
    char buffer[32];
    sprintf_P(buffer, PSTR("G1 F%i Z%i X%i Y%i"), int(homing_feedrate[0]), 35, BED_CENTER_ADJUST_X, BED_CENTER_ADJUST_Y);
    lcd_info_screen(lcd_menu_first_run_bed_level_center_adjust, homeAndParkHeadForCenterAdjustment, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR_IF_NOT_DONE(3);
    lcd_lib_draw_string_centerP(10, PSTR("After transportation"));
    lcd_lib_draw_string_centerP(20, PSTR("we need to do some"));
    lcd_lib_draw_string_centerP(30, PSTR("adjustments, we are"));
    lcd_lib_draw_string_centerP(40, PSTR("going to do that now."));
static void parkHeadForLeftAdjustment()
    add_homeing[Z_AXIS] -= current_position[Z_AXIS];
    current_position[Z_AXIS] = 0;
    plan_set_position(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS]);
    char buffer[32];
    sprintf_P(buffer, PSTR("G1 F%i Z5"), int(homing_feedrate[Z_AXIS]));
    sprintf_P(buffer, PSTR("G1 F%i X%i Y%i"), int(homing_feedrate[X_AXIS]), BED_LEFT_ADJUST_X, BED_LEFT_ADJUST_Y);
    sprintf_P(buffer, PSTR("G1 F%i Z0"), int(homing_feedrate[Z_AXIS]));
    LED_GLOW();
    if (lcd_lib_encoder_pos == ENCODER_NO_SELECTION)
        lcd_lib_encoder_pos = 0;
    if (printing_state == PRINT_STATE_NORMAL && lcd_lib_encoder_pos != 0 && movesplanned() < 4)
        current_position[Z_AXIS] -= float(lcd_lib_encoder_pos) * 0.05;
        plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS], 60, 0);
    if (movesplanned() > 0)
        lcd_info_screen(NULL, NULL, PSTR("CONTINUE"));
    else
        lcd_info_screen(lcd_menu_first_run_bed_level_left_adjust, parkHeadForLeftAdjustment, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR_IF_NOT_DONE(4);
    lcd_lib_draw_string_centerP(10, PSTR("Rotate the button"));
    lcd_lib_draw_string_centerP(20, PSTR("until the nozzle is"));
    lcd_lib_draw_string_centerP(30, PSTR("a millimeter away"));
    lcd_lib_draw_string_centerP(40, PSTR("from the buildplate."));
static void parkHeadForRightAdjustment()
    char buffer[32];
    sprintf_P(buffer, PSTR("G1 F%i X%i Y%i"), int(homing_feedrate[X_AXIS]), BED_RIGHT_ADJUST_X, BED_RIGHT_ADJUST_Y);
    LED_GLOW();
    lcd_info_screen(lcd_menu_first_run_bed_level_right_adjust, parkHeadForRightAdjustment, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR_IF_NOT_DONE(5);
    lcd_lib_draw_string_centerP(10, PSTR("Turn left buildplate"));
    lcd_lib_draw_string_centerP(20, PSTR("screw till the nozzle"));
    lcd_lib_draw_string_centerP(30, PSTR("is a millimeter away"));
    LED_GLOW();
    lcd_info_screen(lcd_menu_first_run_bed_level_paper, NULL, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR_IF_NOT_DONE(6);
    lcd_lib_draw_string_centerP(10, PSTR("Turn right buildplate"));
static void parkHeadForCenterAdjustment()
    char buffer[32];
    sprintf_P(buffer, PSTR("G1 F%i X%i Y%i"), int(homing_feedrate[X_AXIS]), X_MAX_LENGTH / 2, BED_CENTER_ADJUST_Y);
    lcd_info_screen(lcd_menu_first_run_bed_level_paper_center, parkHeadForCenterAdjustment, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR_IF_NOT_DONE(7);
    lcd_lib_draw_string_centerP(10, PSTR("Repeat this step, but"));
    lcd_lib_draw_string_centerP(20, PSTR("now use a sheet of"));
    lcd_lib_draw_string_centerP(30, PSTR("paper to fine-tune"));
    lcd_lib_draw_string_centerP(40, PSTR("the buildplate level."));
    LED_GLOW();
    else
        lcd_info_screen(lcd_menu_first_run_bed_level_paper_left, parkHeadForLeftAdjustment, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR_IF_NOT_DONE(8);
    lcd_lib_draw_string_centerP(10, PSTR("Slide a paper between"));
    lcd_lib_draw_string_centerP(20, PSTR("buildplate and nozzle"));
    lcd_lib_draw_string_centerP(30, PSTR("until you feel a"));
    lcd_lib_draw_string_centerP(40, PSTR("bit resistance."));
    LED_GLOW();
    lcd_info_screen(lcd_menu_first_run_bed_level_paper_right, parkHeadForRightAdjustment, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR_IF_NOT_DONE(9);
    lcd_lib_draw_string_centerP(20, PSTR("Repeat this for"));
    lcd_lib_draw_string_centerP(30, PSTR("the left corner..."));
static void homeBed()
    add_homeing[Z_AXIS] += LEVELING_OFFSET;  //Adjust the Z homing position to account for the thickness of the paper.
    // now that we are finished, save the settings to EEPROM
    Config_StoreSettings();
    LED_GLOW();
    if (IS_FIRST_RUN_DONE())
        lcd_info_screen(lcd_menu_main, homeBed, PSTR("DONE"));
    else
        lcd_info_screen(lcd_menu_first_run_material_load, homeBed, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR_IF_NOT_DONE(10);
    lcd_lib_draw_string_centerP(30, PSTR("the right corner..."));
static void parkHeadForHeating()
    lcd_material_reset_defaults();
    enquecommand_P(PSTR("G1 F12000 X110 Y10"));
    enquecommand_P(PSTR("M84"));//Disable motor power.
    lcd_info_screen(lcd_menu_first_run_material_select_1, parkHeadForHeating, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR(11);
    lcd_lib_draw_string_centerP(10, PSTR("Now that we leveled"));
    lcd_lib_draw_string_centerP(20, PSTR("the buildplate"));
    lcd_lib_draw_string_centerP(30, PSTR("the next step is"));
    lcd_lib_draw_string_centerP(40, PSTR("to insert material."));
    if (eeprom_read_byte(EEPROM_MATERIAL_COUNT_OFFSET()) == 1)
        digipot_current(2, motor_current_setting[2]);//Set E motor power to default.
        for(uint8_t e=0; e<EXTRUDERS; e++)
            lcd_material_set_material(0, e);
        SET_FIRST_RUN_DONE();
        currentMenu = lcd_menu_first_run_material_load_heatup;
        return;
    lcd_info_screen(lcd_menu_first_run_material_select_material, doCooldown, PSTR("READY"));
    DRAW_PROGRESS_NR(12);
    lcd_lib_draw_string_centerP(10, PSTR("Next, select the"));
    lcd_lib_draw_string_centerP(20, PSTR("material you will"));
    lcd_lib_draw_string_centerP(30, PSTR("insert in this"));
    lcd_lib_draw_string_centerP(40, PSTR("Ultimaker2."));
static char* lcd_material_select_callback(uint8_t nr)
    eeprom_read_block(card.longFilename, EEPROM_MATERIAL_NAME_OFFSET(nr), 8);
    return card.longFilename;
static void lcd_material_select_details_callback(uint8_t nr)
    lcd_lib_draw_stringP(5, 53, PSTR("Select the material"));
    LED_GLOW();
    uint8_t count = eeprom_read_byte(EEPROM_MATERIAL_COUNT_OFFSET());
    lcd_scroll_menu(PSTR("MATERIAL"), count, lcd_material_select_callback, lcd_material_select_details_callback);
    CLEAR_PROGRESS_NR(13);
    if (lcd_lib_button_pressed)
            lcd_material_set_material(SELECTED_SCROLL_MENU_ITEM(), e);
        lcd_change_to_menu(lcd_menu_first_run_material_select_confirm_material);
        strcat_P(card.longFilename, PSTR(" as material,"));
    LED_GLOW();
    lcd_question_screen(lcd_menu_first_run_material_select_2, NULL, PSTR("YES"), lcd_menu_first_run_material_select_material, NULL, PSTR("NO"));
    DRAW_PROGRESS_NR(14);
    lcd_lib_draw_string_centerP(20, PSTR("You have chosen"));
    lcd_lib_draw_string_center(30, card.longFilename);
    lcd_lib_draw_string_centerP(40, PSTR("is this right?"));
    lcd_info_screen(lcd_menu_first_run_material_load_heatup, NULL, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR(15);
    lcd_lib_draw_string_centerP(10, PSTR("Now your Ultimaker2"));
    lcd_lib_draw_string_centerP(20, PSTR("knows what kind"));
    lcd_lib_draw_string_centerP(30, PSTR("of material"));
    lcd_lib_draw_string_centerP(40, PSTR("it is using."));
    setTargetHotend(material[0].temperature, 0);
    int16_t temp = degHotend(0) - 20;
    int16_t target = degTargetHotend(0) - 10 - 20;
    if (temp < 0) temp = 0;
    if (temp > target)
            volume_to_filament_length[e] = 1.0;//Set the extrusion to 1mm per given value, so we can move the filament a set distance.
        currentMenu = lcd_menu_first_run_material_load_insert;
        temp = target;
    uint8_t progress = uint8_t(temp * 125 / target);
    if (progress < minProgress)
        progress = minProgress;
    else
        minProgress = progress;
    lcd_basic_screen();
    DRAW_PROGRESS_NR(16);
    lcd_lib_draw_string_centerP(10, PSTR("Please wait,"));
    lcd_lib_draw_string_centerP(20, PSTR("printhead heating for"));
    lcd_lib_draw_string_centerP(30, PSTR("material loading"));
    lcd_progressbar(progress);
static void runMaterialForward()
    //Override the max feedrate and acceleration values to get a better insert speed and speedup/slowdown
    float old_max_feedrate_e = max_feedrate[E_AXIS];
    float old_retract_acceleration = retract_acceleration;
    max_feedrate[E_AXIS] = FILAMENT_INSERT_FAST_SPEED;
    retract_acceleration = FILAMENT_LONG_MOVE_ACCELERATION;
    current_position[E_AXIS] = 0;
    plan_set_e_position(current_position[E_AXIS]);
    current_position[E_AXIS] = FILAMENT_FORWARD_LENGTH;
    plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS], FILAMENT_INSERT_FAST_SPEED, 0);
    //Put back origonal values.
    max_feedrate[E_AXIS] = old_max_feedrate_e;
    retract_acceleration = old_retract_acceleration;
    LED_GLOW();
    if (movesplanned() < 2)
        current_position[E_AXIS] += 0.5;
        plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS], FILAMENT_INSERT_SPEED, 0);
    lcd_info_screen(lcd_menu_first_run_material_load_forward, runMaterialForward, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR(17);
    lcd_lib_draw_string_centerP(10, PSTR("Insert new material"));
    lcd_lib_draw_string_centerP(20, PSTR("from the rear of"));
    lcd_lib_draw_string_centerP(30, PSTR("your Ultimaker2,"));
    lcd_lib_draw_string_centerP(40, PSTR("above the arrow."));
    lcd_basic_screen();
    DRAW_PROGRESS_NR(18);
    lcd_lib_draw_string_centerP(20, PSTR("Loading material..."));
    if (!blocks_queued())
        lcd_lib_beep();
        led_glow_dir = led_glow = 0;
        digipot_current(2, motor_current_setting[2]*2/3);//Set E motor power lower so the motor will skip instead of grind.
        currentMenu = lcd_menu_first_run_material_load_wait;
    long pos = st_get_position(E_AXIS);
    long targetPos = lround(FILAMENT_FORWARD_LENGTH*axis_steps_per_unit[E_AXIS]);
    uint8_t progress = (pos * 125 / targetPos);
    LED_GLOW();
    lcd_info_screen(lcd_menu_first_run_print_1, doCooldown, PSTR("CONTINUE"));
    DRAW_PROGRESS_NR(19);
    lcd_lib_draw_string_centerP(10, PSTR("Push button when"));
    lcd_lib_draw_string_centerP(20, PSTR("material exits"));
    lcd_lib_draw_string_centerP(30, PSTR("from nozzle..."));
        plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS], FILAMENT_INSERT_EXTRUDE_SPEED, 0);
    lcd_info_screen(lcd_menu_first_run_print_card_detect, NULL, PSTR("ARE YOU READY?"));
    DRAW_PROGRESS_NR(20);
    lcd_lib_draw_string_centerP(20, PSTR("I'm ready let's"));
    lcd_lib_draw_string_centerP(30, PSTR("make a 3D Print!"));
    if (!card.sdInserted)
        lcd_info_screen(lcd_menu_main);
        DRAW_PROGRESS_NR(21);
        lcd_lib_draw_string_centerP(20, PSTR("Please insert SD-card"));
        lcd_lib_draw_string_centerP(30, PSTR("that came with"));
        lcd_lib_draw_string_centerP(40, PSTR("your Ultimaker2..."));
        card.release();
        return;
    if (!card.isOk())
        lcd_lib_draw_string_centerP(30, PSTR("Reading card..."));
        card.initsd();
        return;
    lcd_info_screen(lcd_menu_print_select, NULL, PSTR("LET'S PRINT"));
    lcd_lib_draw_string_centerP(10, PSTR("Select a print file"));
    lcd_lib_draw_string_centerP(20, PSTR("on the SD-card"));
    lcd_lib_draw_string_centerP(30, PSTR("and press the button"));
    lcd_lib_draw_string_centerP(40, PSTR("to print it!"));
#endif//ENABLE_ULTILCD2
Post by Amedee » December 17th, 2016, 10:39 am
This is what the UM2 is doing, yes...
So if you want to do the same for the UMO, it is a good start
Phil.
antiklesys
Post by antiklesys » December 17th, 2016, 1:00 pm
Started working on it, cutting out all the unnecessary "crap" for now.
Will keep you posted :)
Post by Neotko » December 17th, 2016, 5:47 pm
antiklesys wrote:Started working on it, cutting out all the unnecessary "crap" for now.
Maybe this helps?
https://ultimaker.com/en/community/2212 ... mit-on-umo
I don't do an autolevel since I just leave the head x/y motors free so I can move the head and calibrate by eye/gauge feller. So far all works. Ofc it should be pretty easy to add a couple more steps to move the head.
antiklesys
Post by antiklesys » December 18th, 2016, 6:53 am
Not really, this is mostly for custom Z offset while I'm working on a similar routine as the "bed leveling" done in Cura 15...and also I can't do the Z homing at the bottom. I find it highly inconvenient.
This is my work in progress in ultralcd.cpp (has to be read from the bottom up):
Code: Select all
    char buffer[32];
    char buffer[32];
	parkHeadForCenterAdjustment();
    char buffer[32];
	parkHeadForRightAdjustment();
	//still need to fix this one
	parkHeadForLeftAdjustment();
    char buffer[32];
	parkHeadForLeftAdjustment(); //temporary for testing only
	//lcd_menu_first_run_bed_level_center_adjust();
    char buffer[32];
	homeAndParkHeadForCenterAdjustment2();
static void bed_leveling2()
    char buffer[32];
	homeAndParkHeadForCenterAdjustment();
antiklesys
Post by antiklesys » January 9th, 2017, 5:38 am
Hi Amedee,
I'm working on a toshiba flash air implementation.
If you're interested in adding this to your branch, please check:
https://github.com/AmedeeBulle/Marlin/c ... dede0746b1
AND
https://github.com/AmedeeBulle/Marlin/c ... bb6904f19c
I yet have to test it out as I'm waiting for the SD to be delivered:)
Edit 1: Tested and working but you also need to add this: https://github.com/Antiklesys/Marlin-1/ ... cd60ef0f05
drayson
Post by drayson » January 9th, 2017, 6:08 am
Great news :-)
antiklesys
Post by antiklesys » January 12th, 2017, 3:15 pm
I also added a few lines of code to automatically hide system folders and hidden files on SD cards.
Link: https://github.com/Antiklesys/Marlin-1/ ... 7274226942
drayson
Post by drayson » January 13th, 2017, 2:38 am
Great - this I will merge into my branch as soon as I have time - you cant imagine how I like this mod...
antiklesys
Post by antiklesys » January 13th, 2017, 5:12 pm
Glad to be of help :)
Return to “Firmware”
