Hi everybody,
I have a Creality Cr-10 and i'm using Cura 3.4.
Each print i'v done is printing with a "mirror effect" , my print doesn't look like my orginal STL File.
It's like the left side is print like the right side. See attached my stl file and my print.
Do you know what happened?
Tanks
Creality is printing with mirror effect
- 3D Printer(s): Creality CR 10
Re: Creality is printing with mirror effect
Can you post a picture of your assembled 3D Printer.
Creality Cr-10 Printers come programmed. The only way I know to mirror the print. Would be to invert the X-Z-Axis assembly structure.
should look like this
It's look like your picture.
Can the issue came from CURA?
Thanks
Thanks
and when i'm going to prepare -> Move axis -> Z = the printer is going up and down well
When i'm going to move axis -> X = the printer is going back and front
It's does'nt seems to be invert
Looking at the Bottom picture it appears that you have the Y-Axis connectors connected to the X-Axis.
The next picture up from the bottom shows that the Y-Axis connector has the X-Axis connectors attached.
Unless somehow they have been mislabeled
You are so right. I did a big mistake.
Now everything is working well, thank you very much for your answer and for your time.
We're here to help!
You are most welcome!hippolyte50 wrote: ↑July 8th, 2018, 9:51 am You are so right. I did a big mistake.
We have many users here to help you with your 3D Printer questions. So do not be a stranger stay, read and learn.
There is so much here to learn ourselves, helping others keeps our knowledge easily accessible when we need it.
If you learn something that you feel we would benefit from, Post it into the appropriate sub-forum.
- 3D Printer(s): Ender 3
If the prints are mirrored likely one of your stepper motors (x or y depending on which way they are mirrored) is plugged in backwards. Flip the connector around.
