More strange things - extruder just stops?
Is just me or do some of you also have weird things happen? I replaced the stock hotend on my Monoprice select V2 with the Micro Swiss MK10 All Metal Hotend. That appeared to cure all the issues I had with clogged nozzles, at least it will always extrude filament. Well, not exactly, it will stop extruding several layers into the print. I’ve tried 2 different models and both are the same. The print looks good up to the point it just stops extruding. I can stop the print, move the nozzle up and go to the menu selection and extrude filament, no problem. I did not have this issue a few days back when last I used the printer. Just this morning Cure wanted to update so I let before I ran a print. I don’t see anything in the settings that I think could cause that so I at a loss at the moment.
Re: More strange things - extruder just stops?
That's weird...are you having troubles feeding filament into the hot end? Is the temp too cool ?
