Heating failed, Printer halted, Please reset.
Posted: February 12th, 2018, 2:44 am
by Lez0
I get this error when I am trying to heat the bed to 100°C, it happens after about 80°C.
Sometimes I don't get it for a few days, then, like yesterday it happened 5 or 6 times while heating the bed.
I have reset, switched it off and back on again, but it happens again, then it will work OK no problems.
When it is finally up to temperature it works fine.
Anybody got any ideas?
Thanks
Les
Re: Heating failed, Printer halted, Please reset.
Posted: February 12th, 2018, 8:46 pm
Do you have a sheet of cork under your heated bed? Are you using a MOSFET?
Posted: March 7th, 2018, 6:35 am
by Lez0
It is a stock printer.
I have reduced the temperature of the bed to 80 degs for ABS and have had no problem.
For ABS I am using this seems to work OK for me.
Posted: May 25th, 2018, 3:05 am
by Lez0
Hi Paul
This Mosfet thing, is it easy to install, it doesn't look complicated.
Also which one did you use?
Posted: May 25th, 2018, 9:00 am
I bought this one
Shane's video is pretty easy to follow on how to install. Mine's worked great
Posted: May 25th, 2018, 10:16 am
by Lez0
Thanks Paul, this looks so easy I should be able to do it.
