I wrote a bloat-free STL viewer
- Krishty
- 3D Printer(s): DaVinci
Hi fellow makers!
I was having difficulties browsing folders full of STLs. So I wrote my own STL viewer: https://papas-best.com/stlviewer_en (Windows 7 or later)
It’s very quick and you can go to the next file in a folder just with the right arrow key. It helped me a lot, so I thought I’d share it with you.
If something is wrong or if you’re missing anything, just drop me a note – I’m always improving it!
Re: I wrote a bloat-free STL viewer
I used to use K-Studio, but apparently that trial ran out...so now all my STLs (from my Windows File Explorer view) are back to Simplify3D icons
- Krishty
I have actually written a STL thumbnail handler – it’s as lean and fast as my viewer, and I’d *love* to distribute it! However, I wrote it for my company and I’ll need my bosses’ permission. That’ll take a while, I’m afraid
- jonnybischof
STL thumbnails would be great! I have a "downloaded stuff from thingiverse" folder which is taking up like 75% of my dropbox and have no clue what most of that stuff even is
Might take a look at that viewer, thank you for sharing!
- drayson
Whooo... that would be great! have the same issue as jonny... please keep us updated!
Bwtween my R2 and BB-8 builds, I have folders and folders full of pieces that go to each. A preview would make finding the right file (6.9 gb worth) a lot easier!jonnybischof wrote: ↑December 11th, 2017, 2:26 am STL thumbnails would be great! I have a "downloaded stuff from thingiverse" folder which is taking up like 75% of my dropbox and have no clue what most of that stuff even is
- Chaco
nice work, much appreciated
- Krishty
Thank you!
I updated the viewer:
Nice holiday everyone!
- you can easily fix a file’s rotation by selecting Y Up or Z Up in the right panel
- fixed UI problems with colors and zoom
- download: https://papas-best.com/stlviewer_en
Windows 10 is preventing me from installing it
- Krishty
SmartScreen filter? There should be a small option in that window where you can install it anyway. Edit: Yes, click “More Information”, then “Run Anyway”.
That’s bad. It’s based on download numbers (often downloaded files are classified "good", rarely downloaded files are blocked proactively) so I’ll see if I can generate some downloads for the problem to go away …
In any case, thank you for the hint!
Yeah just wanted to let you know
- Krishty
I updated the viewer to support wireframe/solid outline rendering:
I improved compatibility and stability as well (full changelog on the download page: https://papas-best.com/stlviewer_en).
Hi Krishty
Thanks so much for this, it works a treat.
Windows 7 pro 64 bit.
Lezo
Lezo
- Krishty
I’m glad to hear that!
I’ve uploaded a new version with a few minor tweaks. Most importantly, back faces are now rendered instead of hidden. If someone missed that feature, get the latest version at https://papas-best.com/stlviewer_en
Did the Thumbnail preview version make it over yet...that's something I would really like. I do like your program, I use yours and the MS one to quickly open and identify what those STLs are
