Anyone use Polycarbonate (PC) or PETG?
Post by LePaul » February 2nd, 2017, 11:54 am
I'm curious how you like them. I know Ultimaker offers their own brand PC and there are PETG brands out there (Matterhacker) too.
Re: Anyone use Polycarbonate (PC) or PETG?
Post by Izzy » February 3rd, 2017, 12:29 pm
I haven't yet, I think Anders has and I think he mentioned requiring higher temperatures to print for the PC
Dim3nsioneer
Post by Dim3nsioneer » February 3rd, 2017, 2:18 pm
Ultimaker PC prints at 260°C; w/o fans. And it gives excellent results. Toughness, interlayer adhesion and even print finish are quite amazing. I printed it even without brim just on the glass (at 113°C, max. of my UM2) with a film of PVA slurry on it.
Post by LePaul » February 3rd, 2017, 3:16 pm
Can you sand PC or PETG for a painted finish?
danilius
Post by danilius » February 5th, 2017, 12:45 pm
I use cheap(ish) PETG from amazon, and I really like the material. It gets quite stringy when damp, but a few hours in a food dryer cures that. Otherwise, it prints well at high temps and is incredibly strong. It's greatest strengths are inter-layer adhesion and springiness. If you need to make a part with a built-in spring, there is little if anything to beat it.
Post by LePaul » August 11th, 2017, 10:41 am
I have had mixed luck with Polycarbonate (Ultimaker brand) and one thing I am curious about...how to make it print clear. Can that be done? I know some materials that are "transparent" can do this, but not sure about PC
Post by Anders Olsson » August 11th, 2017, 11:45 am
I haven't printed Polycarbonate recently. The early types required very high temperatures, but recent versions like the Ultimaker branded one is apparently easier to print.
Both PC and PETG (Colorfabb XT) are hygroscopic and might need drying when the spool has been open for a while.
PETG can be dried at ~70 C for half a day or so.
PC its a bit more tricky as you probably need to get up to ~100 C to dry it properly, which means the spool might deform.
I recall unwinding the amount I needed before drying it.
Both materials should be possible to get reasonably clear, IF they are properly dry. Any humidity will ruin the quality though.
Post by LePaul » August 11th, 2017, 1:43 pm
It's been very humid the past few days (60-70%) but the dehumidifier in the basement/shop area has worked well. So far my polycarbonate has not shown any symptoms of absorbing water (no pops, steam or sizzle)
Post by LePaul » September 6th, 2017, 9:59 am
I know one BB-8 builder ran into an issue where his PETG parts would not fit....he had to re-print them 1% larger to accommodate shrinkage.
