Printing without a LCD or wireless option
AkiraKurai
3D Printer(s): reprap
Post by AkiraKurai »
I'm using a radds board without an LCD screen and want to print using an SD card or any other method available.
Is it possible to print without an LCD screen or is it a must of you want to print from an SD card.
Re: Printing without a LCD or wireless option
Post by reibuehl »
Depending on your firmware, something like the Autostart functionality in the Marlin firmware might be a way to do this. If your firmware supports this, then it should be sufficient to save your file with the name auto0.g on the card and then insert it and turn your printer on.
martin-bienz
Post by martin-bienz »
Well, if you have the option to connect a raspberry pi, octoprint might be the way to go. With octoprint you can either stream directly or print from SD. http://octoprint.org/
Return to “General Questions”
