So I use both 3Ds Max and Maya to create and design models etc.
But I seem to be having an issue with Max output models in OBJ but not in Maya.
Do anyone else use Max OBJ? if so how you setting up your model and then exporting?
Are you using STL or OBJ?
Thanks
Stu
3Ds Max or MAYA
- rokhdrone1uk
- 3D Printer(s): Hictop i3 3DP12
Re: 3Ds Max or MAYA
Moderator note.....I moved this to the CAD and 3D modeling section
- ivan.akapulko
Re: 3Ds Max or MAYA
Both of them is too expensive... SpaceClaim is a very good alternative, imo. About OBJ: never use them. OBJ have any benefits in comparsion to STL?
