Just saw this ...
https://www.sparkfun.com/products/14032
I wonder if something like this would be useful in 3D printing?
LIDAR
- jonnybischof
Re: LIDAR
Accuracy is +- 2.5 cm. So - not useful as a limit switch at all (also the price...
Optical limit switches are not ideal anyways because they are vulnerable to dirt and dust, and sometimes also stray light. If you need something better than a regular mechanical limit switch, I would recommend a hall-effect sensor. They are very accurate and don't suffer from the negative points of optical sensors. And usually optical and hall effect sensors are very similar in price.
