Ultimaker just released a bunch of materials!
- Meduza
Ultimaker just released a bunch of new materials:
https://ultimaker.com/en/products/materials
The materials are CPE+ (a new co-polyester filament), Polycarbonate, Nylon and TPU 95A (flexible)
Re: Ultimaker just released a bunch of materials!
Good read..and whoever Lana is...pretty lady
I wonder which of those materials would be the best for my BB-8 build. CPE+ and PC seem to have the strong and heat resistance I would like.
I thought for polycarbonate we needed to push upto 300'C?
- Meduza
There has been some development in that area, and there now is "low"-temperature polycarbonate that can be printed around 260C and warps less, Polymaker has had some PC like this since late last year: https://3dprint.com/95697/polymaker-covestro-filament/
- Dim3nsioneer
Yes, but forget PC on an UMO+. Those new materials are designed for the UM2+. Even an UM2 without the TFM would have a problem.
- jonnybischof
55 EUR for a 750g spool?
Well, it has to be VERY good to justify that price
I wonder how their Nylon compares to Taulman's (Taulman Bridge is roughly 20% cheaper!)
- Dim3nsioneer
Ultimaker Nylon is much less humudity sensitive than other Nylons.
- Meduza
It is also stiffer than most of the Taulman nylons from what i have heard... (i have not tried it myself tough), also the TPU is supposedly quite easy to print and insanely tough.
- jonnybischof
That sounds interesting... Maybe they finally decided to actually offer good materials on their name
- Dim3nsioneer
The TPU is just great. Prints nice and has an excellent finish.
- drayson
Acc. to the material settings it´s just for UM2 and up, bit not for UMO - right?Dim3nsioneer wrote:The TPU is just great. Prints nice and has an excellent finish.
- Meduza
Correct, all of these new materials requires the machine to operate in the higher temperature range (245-260) wich the UMO+ hotend does not support.
If you replace your printhead with a UM2 one, then you would probably be able to use them.
Probably umo/umo+ also would (for some materials) need side panels and frontal door (or a plastic box covering all except the top and bottom so the cpuboard doesn't fry.
I think umo could print all the new stuff, probably slower, with less coupler life time (peek can work at 255) and ofc some side/frontal covers.
Ofc now that um2+ has a more accurate pt100 and they are selling a front door + bed adhesion helpers, they offer materials for their top machines, umo originally was just pla, and with hotbed can do much more but they can't guarantee umo/umo+ print ability on a system with so many mods, open design (the side panels) and a peek that limits the maximum heat.
- drayson
Side pannels and front door is not a big deal (already did),
a reliable cooling for the CPU board can be tricky (tried a few designs but have not found "the ideal" up to now), but doable,
but to change the whole head means investing money.
Just checked the prices of indeed questionnable china clones... you don´t know what quality you get, but spend also a few bucks for 2 Olsson blocks and head assembly... and I don´t know which parts of the UMO I can reuse - Heater cartridges? Sensors?
And that´s a lot of effort to just be able to print sometimes in more ridgid materials like nylon or TP. Honestly, I don´t know if it is worth...
