Hictop using K3 Bed
Hictop using K3 Bed
I am posting my Hictop 3DP12 3D Printing on a Anycubic Kobra 3 smooth bed surface.
Try it you will like it. This Spring steel bed is quite a bit larger than the original bed.
I centered it between the frame clipped it onto bed and started my normal nozzle height adjustments and printed.
Note that even the bed texture transferred to my model. Another benefit was the Spring steel bed was leveler than the original ever was
