Wow they have a Model Predictive Temperature Control in Marlin 2.1.2.2 when did this happen?
I need to read and figure out how to implement it into my 3DP11/12 Hictop Firmware.
Marlin 2.1.2.2
Re: Marlin 2.1.2.2
I'm not sure when but when I upgraded the boards on my CR-10S machines to SKR Mini E3v3, i enabled it on all of those machines and others since. Very stable temps as I view it in Octoprint. Only con is it seems you can only add in the values after testing via vscode I couldn't find how to put those in very command like like you would a PID Auto tune
Re: Marlin 2.1.2.2
I will look into that before attempting to upgrade with Model Predictive Temperature Control.
Will see if someone has came up with instructions to make it simpler for the rest of us..
Re: Marlin 2.1.2.2
From what I have seen on various Reddit posts and my experience... works great on most hot ends. The only ones I have heard with issues are the E3D Revo hot ends, since they are such a different creature.
Re: Marlin 2.1.2.2
Well that is a positive note for me anyway.
