Lays down raft nicely, then balls of fuzz. Keeping it real
Posted: May 9th, 2024, 1:51 pm
First off, my apologies, I am just now getting BACK into 3D printing after life got in the way and I paused for 2 years. And apparently what I knew fell out of my ears...
Anyway, not sure how to upload images to share here and my online photo sharing is Google Photos, sorry about that...
https://photos.app.goo.gl/SVuaMC3kg6W5o9yb7
So here is the situation. Trying to print a case for a Raspberry Pi 5 with an NVME base, (Pimoroni for anyone that cares).
I got the top printed and it is a thing of beauty, but when I went to print the bottom, what you see in the pic is what I am getting.
Printer is a Voxelab Aquila, the G32 board model with the horizontal display. Only add ons to it are a PEI build plate instead of glass, a Capricorn bowden tube, and a not yet installed Creality all metal extuder upper assembly. Not a fan of the OE plastic ones...
Slicing software is VoxelMaker using the Aqulia PLA profile, cooling fan speed is Always Off and 50%, hot end is set to 220deg C which does GREAT with build surface adhesion anyway. And infill left default except top and bottom solid layers are set to 4 to improve strength somewhat.
And in 100% full disclosure, I may be an idiot. I just double checked and I thought I had the printer loaded with PLA, and nope, it is PETG... Going back to the slicer....
So let my post here serve as a warning. Know what filament you are loading...
