Hi everyone,
Only a part of my stl is being printed.
here is what i have done with my object:
-i added a couple of planes in freecad on the top and back of the object to make it solid
-then in freecad I followed all of these instructions on doing a mesh repair to make sure it is a solid surface without any holes:
https://all3dp.com/1/7-free-stl-editors ... stl-files/
-then in cura I reduce the scaling down to about 4000% so it's small, put on support, and make the object flush with the bed.
i've attached my stl here.
could anyone tell me what the problem is?
not printing my stl properly
- Attachments
- bubba with texture and planes.stl
- (983.24 KiB) Downloaded 948 times
Re: not printing my stl properly
The problem could be in the stl export.
If you try Superspicer it will open up a 3mf file, for all I know Cura might too. In FreeCAD you just select the body from the left window and export as 3MF. No meshing, no complicated procedure, no VooDoo, that's it.
- Country_Bubba
Viewing the stl, it still shows that it is not watertight
sounds great, i'll see if that works
hi again country,Country_Bubba wrote: ↑May 3rd, 2023, 7:36 am Viewing the stl, it still shows that it is not watertight
how are you checking if it's watertight in cura? maybe i'll have to get fusion so i can follow your method properly. after looking into freecad there are apparently several limitations it has, so i'll try another cad software.
- Country_Bubba
I downloaded your latest file and first looked at it in a stl viewer and then confirmed it in Cura.
I first noticed defects and it looks even worse in Cura!
ok. it seems like the only problem to get it printing properly is making it watertight. i'm looking into what i may be able to do in blender as i get the impression the problems stem from there. and i might be able to try out fusion soon too so i'll give updates about that.Country_Bubba wrote: ↑May 4th, 2023, 8:11 am I downloaded your latest file and first looked at it in a stl viewer and then confirmed it in Cura.
i'm sure being able to 3d print heads and faces would be useful to a lot more people than me so hopefully i'll manage to find a solution soon.
