Magnetic bed surface
Hi all
I have been using a vinyl bed surface and it works really well.
The trouble is it's hard to remove when I want to replace it, it takes ages.
I hear there are magnetic surfaces, has anyone used one, and if so does it work OK.
Thank all
Mr SNG
Re: Magnetic bed surface
Post by Mr SNG »
I've just bought one of these to try out, its quite cheap and can be trimmed down to fit my Hictop heatbed.
Also the adhesive sticker is made by 3M which is good quality.
Hi Mr SNG
I have looked at these. Have you seen this?
Very informative.
I just bought a magnetic build plate / spring steel sheet for my Ultimaker 2+ Goes on top of a fresh piece of glass (from Ultimaker).
https://www.printedsolid.com/products/f ... er-2-and-3
