Recently I redid my maker select v2 with a ramps 1.4 and ATX PSU upgrade. It's fantastic, I highly recommend it (even though it took forever). The instructional I found said to use terminal blocks to connect the wires, so I did that. I don't recommend it. Not only is it a royal pain to fit everything into the case, but the terminal blocks are finicky.
Got a notification while printing that my bed temp wasn't correct, checked the graph on octoprint and both temps had just dropped off. So I went down to check and the printer smelled like cancerous death. Took it apart and sure enough, the terminal blocks failed. Thank god octoprint/klipper/ramps/whatever was smart enough to cut off power, since it's in the basement I wouldn't have noticed until probably far too late.
Friendly reminder to make sure your wiring is done properly
Jump to
- Announcements
- ↳ News and Announcements
- 3D Printers
- ↳ General / RepRap Printers
- ↳ HICTOP RepRap Prusa I3
- ↳ Hardware Modifications
- ↳ General Questions
- ↳ Large Scale 3D Printers
- ↳ Tevo brand 3D Printers
- ↳ Resin 3D Printers
- ↳ Micro 3D Printers
- Ultimaker Printers
- ↳ Ultimaker S5
- ↳ General Discussion
- ↳ Special brand filaments
- Getting better prints!
- ↳ Help me fix this print!
- Software & Electronics
- ↳ Slicers and CAD Software
- ↳ Cura
- ↳ Simplify 3D
- ↳ Other Slicing programs
- ↳ Slic3r
- ↳ Electronics
- ↳ Firmware
- ↳ Firmware
- General
- ↳ Off Topics!
- ↳ The MarketPlace
- Modders Kiosk
