Hello, I have been looking for the best 3D printers that would suit me and I came across the following
1.ANYCUBIC Photon UV
2.ELEGOO Mars UV
3.Comgrow Creality Ender 3 Pro
4.Ultimaker 2+ 3D Printer
5.Sindoh 3DWOX DP200
I would love an expert view on this. I have attached the source article see if it will influence your judgment.
Source: https://improvecraft.com/best-3d-printe ... iniatures/
Best 3D Printers for Miniatures
Re: Best 3D Printers for Miniatures
I have had an Anycubic Photon (not the S) for 18 months and it works well. I lot depends on the resin you use and what you want if for.
I started with the Anycubic resin then moved to Elegoo ABS-Like resin and found it suited my needs better.
The Anycubic photon as a good following on Facebook so you can get advice if you need it.
Thank you lez
