GMASS - Tungsten, X-ray shielding filament from Turner Medtech
New or specialty stuff? Let's talk!
Post by Anders Olsson »
So, I we received a spool of Tungsten filament the other day and here is my preliminary review of this interesting material.
This ABS-filament with tungsten particles is marketed as printable radiation shielding and also as a dense plastic that can be printed to weigh down things: http://turnermedtech.com/gmass.html
At the moment, it only comes in 1.75 mm, which means you need a rebuild kit if you are an Ultimaker user.
We intend to use this for printing components for our X-ray diffractometers, here is an example of a test piece I made:
(This one does not have a particular purpose other than testing how well this filament prints)
I was also interested in how this works with ruby nozzles, as I heard horror stories about this basically being unprintable with brass nozzles because of the rapid nozzle wear.
If any of you consider testing this filament, here are a few comments:
- The printing temperature stated in the instructions is 200-230 C, which is surprisingly low. I have never managed to print ABS well below 240 C and I mostly print at 260. I had to increase the temperature to 260 for the GMASS to print well too.
- Using the TESA Easy Stick glue to make it stick to the glass plate works well just as with other ABS filaments.
- A nozzle size of 0.5-0.6 mm is recommended, it does print with the 0.4 mm nozzle too though.
- This filament has really odd extrusion characteristics. I am still confused to how difficult it is to extrude.
I had to print at 20 mm/s (0.15 mm layers) as my direct extruder would skip at higher speeds.
My boron carbide filament as a reference, which has a much larger fraction of particles both by weight and by volume, extrudes quite similar to pure ABS. So either Turner Medtech used some really weird ABS grade for this filament, or there is some effect of the particles that I don't yet understand.
- There seems to be a very wide range of particle sizes in the filament, some of them are HUGE, at least 0.1 mm.
I would therefore recommend at least 0.15 mm layer height (as the manufacturer does) with no less than 0.3 mm initial layer.
The last point means the ruby is not safe anymore. Tungsten may be softer than Ruby but the sheer size of some of the particles means you can still break chips off the ruby. Here is how the tip looked after a few hours of printing:
That wear will not affect the printing quality and the nozzle will likely survive for a long time, but it is good to be aware of this.
I used diamond lapping film to polish the bottom surface of a print to check for large grains and here is how it looks.
The line width of this first layer became a bit uneven, but the average of two lines is 0.8 mm. You can imagine when I started printing at 0.2 mm initial layer, which was more like 0.1 mm in reality, and those huge particles get caught between the glass plate and the ruby (you will hear it :roll:)
That is why I would not print with less than 0.3 mm initial layer.
For weighing down things I would actually recommend using Colorfabb bronze/brass/copper-fill instead as it has similar density but is much cheaper, easier to print and does not wear the nozzle at the same rate.
For X-ray shielding this thing is, although a bit difficult to handle, still highly interesting! :-)
Re: GMASS - Tungsten, X-ray shielding filament from Turner Medtech
Post by ivan.akapulko »
200$ for a roll? Holy hell...
So use this for my Batman suit to handle the kryptonite against Superman? :)
LePaul wrote:So use this for my Batman suit to handle the kryptonite against Superman? :)
Not sure about the kryptonite, but for protection against X-rays it should work :-D
Just came across this one: the french Nanovia is also producing X-Ray shielding filament see here...
Interesting link, thank you Amedee!
I thought that Turner Medtech's "patent pending" statement would scare competitors away, but apparently not, which is good :-)
We have been discussing making our own tungsten filament at work, using a more suitable particle size and a polymer that prints better.
Not sure it will be time for that anytime soon though.
Another interesting thing that my boss mentioned, that I did not think of, is that other materials like bronze fill will also be shielding X-rays!
Tungsten might be a bit more optimal, but for some applications bronze/brass/copper/iron might be good enough :-)
MTVDNA
Post by MTVDNA »
A bit late to the party, but still: out of curiosity, why do you use tungsten and not lead? It might be a lot easier to print, since it's quite soft?
Meduza
Post by Meduza »
Might be because of the heavy metal toxicity and environmental impact of lead...?
maida
Post by maida »
Hi, Does any one know any other ABS filament that has a higher density than GMASS tungsten (4 g/cc)?
Like any gold, lead, stainless still, or any other material that can also be used for X-ray shielding...
maida
Post by maida »
Amedee wrote:Just came across this one: the french Nanovia is also producing X-Ray shielding filament see here...
Hi, What is the material name or properties?
Do you have any contact number from them ?
maida
Post by maida »
You don't use lead because the density of Tungsten is higher I think.
maida wrote: Hi, What is the material name or properties?
It's called PLA XRS -- I don't know much more about it...
There is an e-mail on their contact page, they are on twitter as @nanovia_tech.
Alternatively you can contact Riggs on the forum he has good contact with them.
pmillho
3D Printer(s): MP Select Mini
Post by pmillho »
Does anyone know the weight percent of tungsten in the GMass Tungsten filament? Can't find this information anywhere.
We have some of the GMass left and it's nice stuff but will run out shortly. Also in the market for a replacement... Tungsten PLA would be nice.
I reached out to Nanovia about their XRS PLA.
Also came across this (currently unavailable as well):
https://filaments.ca/products/pla-filam ... ill-1-75mm
Return to “Speciality and Experimental Filaments”
