Cura stuck at 0% infill
Let's talk about the slicers, CAD and other software you use for your prints
Vainstains
3D Printer(s): Wanhao powerspec I3+
Post by Vainstains »
So I opened up cura for wanhao, uploaded a model, but the infill % was stuck at 0%. I deleted all files even named something like cura, redownloaded the softwarehttp://www.wanhao3dprinter.com/Down/Sho ... ticleID=56, and it STILL was locked to 0% infill. common issue?
Vainstains
Re: Cura stuck at 0% infill
the greyed out digits and symbols means i can't change it
Infill Density looks like 100%, not 0%. Try hitting the arrow (next to the box) to reset to default value.
Vainstains
it is greyed out, but that also means that it is set to 0. sorry for being unclear. also, thx, but did not work. still no infill.
This might help the cause?
AIl_In_One_3D_printer_test_micro.stl
(969.61 KiB) Downloaded 1106 times
Screen Shot 2019-01-25 at 11.47.34 PM.png (11.51 KiB) Viewed 31642 times
Just a shot in the dark here...have you tried downloading the 3.6 Cura and experimenting in there?
Vainstains
yes, but i only have mac, they all crash, exempt for cura for wanhao. thats what i use.
I can't say the recent builds have impressed me much....the settings are just a mess...I'm using Simplify 3D more and more these days
Vainstains
cura for wanhao is the only thing that works for me. it made me a 1x2x3 rubiks cube... ...right before it lost infill. sometimes i write a very simple geode file from scratch. i made a tetrahedron.
Vainstains
Fixed it! just go into printer profiles, exit yours, then enter yours again. Simple!
Return to “Slicers and CAD Software”
