Hi All
I have been trying to print with ABS with various results.
One problem I am having like everyone else is sticking the ABS to the bed.
I have tried making slurry but the ABS will not dissolve even after a few days.
I am using pure Acetone and cut 1.75 filament straight off the reel.
According to the web the ABS I bought from Folger is not true ABS.
Has anyone else had this problem.
Folger ABS
Re: Folger ABS
I haven't tried ABS at all but I would be curious if your bed is able to get to temp ok? I installed a MOSFET and placed cork tile under my bed
Re: Folger ABS
I can get the bed to over 100°C, it does take a little time.
I have been using glue but it doesn't always work with ABS.
Re: Folger ABS
I'm having good luck with PEI on my other printers.
Re: Folger ABS
I found some "normal" ABS and it dissolved in minutes, so it is the Folger ABS that's the problem.
I got this reply frm Folger:
It is mainly ABS but there are some additives as well.
Thanks,
Folger Tech Team
Now we know.
Thanks,
Folger Tech Team
Now we know.
Re: Folger ABS
Glad to hear you're got a solution!
Re: Folger ABS
The "ABS Slurry" worked very well. It was like a thick milk when I applied it to the glass.
