Hictop 3DP-08: Firmware not working properly
- 3D Printer(s): Hictop 3DP-03
Re: Hictop 3DP-08: Firmware not working properly
My "Vxy-jerk" in the LCD menu says "20", which is the same as the lines that are commented out in configuration.h, if that's relevant.
Then you need to disable these lines
//#define FIX_MOUNTED_PROBE
//#define AUTO_BED_LEVELING_BILINEAR
And I would enable
//define this to enable EEPROM support
#define EEPROM_SETTINGS
This allows you to change your setting Using M502 and M500 and test without reflashing
Below this line "#define REPRAP_DISCOUNT_SMART_CONTROLLER // CL: Stock HICi3 20x4 LCD controller"
add
#define NEWPANEL // enable this if you have a click-encoder panel
And I would enable
add
Don't know if it makes much difference but I use 1 not 3 on these
* 1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
* 2 : 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
* 3 : Mendel-parts thermistor (4.7k pullup)
#define TEMP_SENSOR_0 3
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_BED 3
Sorry error enable this
My bed thermistor reads 108k ohms and the hot end reads 117k ohms. Should I use option 1?
They were changed to 5
And I did not see a difference when I changed them
Last edited by Roberts_Clif on August 13th, 2017, 12:47 am, edited 1 time in total.
Ok, I have your file now
You will need this
G code and M code master list
Original Firmware download, It would have been nice it they had the source code and not just the hex code.
https://www.hic3dprinter.com/pages/firmware
Last edited by Roberts_Clif on August 13th, 2017, 1:06 am, edited 1 time in total.
With you so far.
That about it.
Except printing a 20x20mm test block, and remembering where your firmware backup can be downloaded.
Last edited by Roberts_Clif on August 13th, 2017, 1:16 am, edited 1 time in total.
What programmer do I select in the Arduino IDE? And then I just build and upload it?
Arduino/Genuino Mega or Mega 2560
Processor
ATmega2560(Mega 2560)
Then of course the Port
Processor
What do you have selected in the menu Tools->Programmer (below "Get Board Info")?
