Cura 3.2.21 stretches X in gcode
kek
3D Printer(s): Lulzbot TAZ5
Post by kek » August 4th, 2018, 11:57 am
OK, I've spent the past hour and a half searching the web with no luck:(
I was using Octoprinter to control my Lulzbot TAZ5, but since Octoprinter doesn't support Cura 3.2.21, I'm now direct-connecting to the printer.
When I load the stl file Cura correctly displays the envelope dimensions, however when the parts print, they are stretched in the X direction by about 25%.
Any ideas on how to correct this - short of manually scaling the model in the X direction to "fool" the slicer?
Kind regards,
Randy
Re: Cura 3.2.21 stretches X in gcode
Post by GrueMaster » August 4th, 2018, 6:15 pm
Think I am missing something here. I use Cura 3.4.1 (and have used 3.2.1 in the past) to connect to Octoprint with no problem. Are you using Octoprint to do the slicing? If so, that is using a very old CuraEngine (prior to Ultimaker taking over development). Recommend just slicing on PC and sending the gcode to Octoprint.
Post by LePaul » August 5th, 2018, 10:42 pm
The plug in was bad. Remove it and install the plug in again. Or go to the newer version of cura
kek
Post by kek » August 6th, 2018, 10:55 am
I've given-up using Octoprint and am now direct USB connecting to Lulzbot TAZ5 - this is where the problem of stretching occurs: BTW it is "Y" not "X" (got my directions mixed-up)
The "Propare" tab selected, the envelope size is correct, and the part "looks" correct (ie. no stretching in the view port). This is what leads me to believe that the Y-stretching is happening in the gcode.
Return to “Cura”
