UM2 Pinout Grafic?
Posted: February 17th, 2018, 6:12 am
by reibuehl
Does anybody of you have a PDF or grapic version of the UM2 Mainboard pin out? Or a version of Altium Designer to create one for me from the Altium files published by Ultimaker? A board view with the pins labled and if possible a schematic would be perfect but I would need to know at least where to find the PC7 (D30) and PD7 (D38) pins.
Re: UM2 Pinout Grafic?
Posted: February 17th, 2018, 9:35 am
by reibuehl
I found an older schematic, but that looks like the pins I thought could be used are different than what Marlin expects... is there a digital pin free that could be used for a filament sensor?
Posted: February 17th, 2018, 10:09 am
by reibuehl
Looks like I found my pins on the EXT/IO header:
Posted: February 23rd, 2018, 3:05 am
by jonnybischof
Is 2.1.1 still up to date?
I use Altium Designer at work, so I can open the original source files and make any kind of documentation output you want...
Posted: February 23rd, 2018, 4:20 am
by reibuehl
The latest version for the UM2 and UM2+ is 2.1.4 which can be found in git.
It would be great if you could create an updated PDF for that version, @jonnybischof. Schematics, top/bottom Silkscreen and maybe the top/bottom 3D view would be perfect. I do not need the copper layers or such. Maybe a parts list, too if that is not too much work?
Posted: February 26th, 2018, 3:00 am
by jonnybischof
Ok, working on it.
Can do even better documentation, Altium has a new (for some time now) documentation tool which is really awesome.
Will use this occasion to do some "training" with the tool ;)
Posted: February 26th, 2018, 6:02 am
by jonnybischof
Done.
Now let's see if the forum lets me upload all that stuff...
Looks like it does <3
Ultimainboard V2.1.4 Bill of materials.xlsx
(17.97 KiB) Downloaded 1550 times
Bill of materials. Unformatted (takes a lot of time). I just took those fields that made sense. The database is not very tidy so I didn't want to put too much effort into it.
Ultimainboard V2.1.4 schematics.PDF
(1.59 MiB) Downloaded 2802 times
Schematics, PDF export of original files
Ultimainboard V2.1.4 PCBA overview.pdf
(151.52 KiB) Downloaded 2098 times
Documentation output showing the connections and pinout
Ultimainboard V2.1.4 PCBA dimensions.pdf
(103.42 KiB) Downloaded 1310 times
Documentation output showing the PCB dimensions
Ultimaker_V2.1.4 3D step.zip
(2.81 MiB) Downloaded 1166 times
3D step export
If you need anything else, just ask ;)
Posted: February 26th, 2018, 6:37 am
by reibuehl
Wow! Very nice job! I love the detail magnification of the pins. Many thanks! I wonder if Ultimaker would accept a git pull request with these files :-)
