Heating failed, Printer halted, Please reset.
Post by Lez0 » February 12th, 2018, 2:44 am
I get this error when I am trying to heat the bed to 100°C, it happens after about 80°C.
Sometimes I don't get it for a few days, then, like yesterday it happened 5 or 6 times while heating the bed.
I have reset, switched it off and back on again, but it happens again, then it will work OK no problems.
When it is finally up to temperature it works fine.
Anybody got any ideas?
Thanks
Les
Re: Heating failed, Printer halted, Please reset.
Post by LePaul » February 12th, 2018, 8:46 pm
Do you have a sheet of cork under your heated bed? Are you using a MOSFET?
Post by Lez0 » March 7th, 2018, 6:35 am
It is a stock printer.
I have reduced the temperature of the bed to 80 degs for ABS and have had no problem.
For ABS I am using this seems to work OK for me.
Post by Lez0 » May 25th, 2018, 3:05 am
Hi Paul
This Mosfet thing, is it easy to install, it doesn't look complicated.
Also which one did you use?
Post by LePaul » May 25th, 2018, 9:00 am
I bought this one
Shane's video is pretty easy to follow on how to install. Mine's worked great
Post by Lez0 » May 25th, 2018, 10:16 am
Thanks Paul, this looks so easy I should be able to do it.
