Im just having a terrible time getting a good print. I have covered the basics and keep running into one issue after another.
Latest issue, cura adding support structure where none is wanted. I have this drawing, has large open areas. I want to print with no support. So, in cura the layer view shows no support, just as I want. However, when it prints, it makes the support framework inside my open areas. Reason I do not want support is because I am printing in armadillo tpu 75d, and this stuff is extremely tough. Its nearly impossible to cut these supports out once its finished. The filament sticks fine on blue tape so no support is needed. Inside the open areas, there is no over hang, just vertical wall.
What am I doing wrong? I am having many troubles with cura not interpreting the stl files correctly.
More issues with cura and bad prints!
Re: More issues with cura and bad prints!
It looks like you are printing with either a brim or raft. Print with a skirt and see what it looks like. You can also preview the print by switching to the gcode view in Cura.
Which version of Cura are you using? If it is the old 15.xx, I highly recommend upgrading to the latest.
Im using version 2.5. That print was made with no support enabled. I noticed that it came out flipped 180 from the drawing. So, I must have somehow fliped it in cura. Why would cura not be able to correctly slice if the drawing is flipped?
Brim/raft is not considered support. It is actually under Build Plate Adhesion. For this model, I recommend only a skirt, which are a series of lines printed around the object, but never touching it. This is primarily used to prime the print head before starting to print the first layer, but also helps as an early warning of bed adhesion issues.
OK, Thanks! I will investigate the build plate adhesion.
Grab the latest version of Cura too
