G-Code commands not executing ? and a newbie hello !
Posted: September 11th, 2017, 6:03 am
Hi all,
I'm Stuart, I've been 3D printing at home for about 2 years now, though I couldn't even tell you what kind of printer I have - it was a Chinese kit from Amazon, since discontinued - I've had to start from pretty much first principals, upgrading bits and bobs, calibrating it all etc, but it works pretty well now - an excellent learning experience !
Anyway, I've noticed that sometimes I get G-Code that doesn't execute.
I use Slicr, and as you know, it has two blocks of automatically inserted startup g-code and lets you insert your own custom code in the middle. The code I want to run looks like the following:
as you can see, my custom code moves the (x,y) origin so that it is on the bed (the home position is slightly in front of the bed, probably a good thing or I'd get a clot of dribbled plastic on the bed). My code also lifts the nozzle.
The trouble I have is that sometimes my code doesn't execute when I'm running from an SD card - the printer doesn't move but just goes straight from bed heating to nozzle heating. Worse still, the hardware seems to think it has raised the z axis by 3mm when it actually hasn't, so when it starts printing, it ploughs a furrow through my blue tape.
I suspect it's something to do with the M190 command, 'set bed temp and wait', I'm guessing that the 'wait' part confuses the processor so that it skips the following commands - if I start the print job when bed and nozzle are already spot on temperature then the code executes fine and the nozzle moves. I don't have the problem if i run the code tethered to the laptop instead of from SD card.
Any ideas what causes this, and how I could fix it ?
Cheers,
Stuart
(I don't really have my bed at 80 degrees in case you're wondering, my bed sensor is wrong, reads in the 40's at room temperature !)
Code: Select all
M107
M190 S80 ; set bed temperature
M104 S200 ; set temperature
; above 3 commands are slicr-generated
; below is my custom code
G21 ; set units to mm (slicr adds later, but am moving bed, so do here)
G90 ; set absolute coords (ditto)
G92 X0 Y-15 Z0 ; adjusts so (0,0) is on the bed, adjust to suit
G1 Z3 F3000 ; lift nozzle
G1 X0 Y0 F4800 ; home x and y
; and from here on is slicr-generated
M109 S200 ; wait for temperature to be reached
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusionThe trouble I have is that sometimes my code doesn't execute when I'm running from an SD card - the printer doesn't move but just goes straight from bed heating to nozzle heating. Worse still, the hardware seems to think it has raised the z axis by 3mm when it actually hasn't, so when it starts printing, it ploughs a furrow through my blue tape.
Cheers,
Stuart
