Page 3 of 4
Re: Hictop 3DP-08: Firmware not working properly
Posted: August 13th, 2017, 12:18 am
by ieatacid
My "Vxy-jerk" in the LCD menu says "20", which is the same as the lines that are commented out in configuration.h, if that's relevant.
Posted: August 13th, 2017, 12:32 am
Then you need to disable these lines
//#define FIX_MOUNTED_PROBE
//#define AUTO_BED_LEVELING_BILINEAR
And I would enable
//define this to enable EEPROM support
#define EEPROM_SETTINGS
This allows you to change your setting Using M502 and M500 and test without reflashing
Below this line "#define REPRAP_DISCOUNT_SMART_CONTROLLER // CL: Stock HICi3 20x4 LCD controller"
add
#define NEWPANEL // enable this if you have a click-encoder panel
Posted: August 13th, 2017, 12:35 am
Don't know if it makes much difference but I use 1 not 3 on these
* 1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
* 2 : 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
* 3 : Mendel-parts thermistor (4.7k pullup)
#define TEMP_SENSOR_0 3
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_BED 3
Posted: August 13th, 2017, 12:37 am
Sorry error enable this
Posted: August 13th, 2017, 12:44 am
Here
Configuration.h
(56.05 KiB) Downloaded 400 times
by ieatacid
My bed thermistor reads 108k ohms and the hot end reads 117k ohms. Should I use option 1?
Posted: August 13th, 2017, 12:46 am
ieatacid wrote: August 13th, 2017, 12:18 am My "Vxy-jerk" in the LCD menu says "20", which is the same as the lines that are commented out in configuration.h, if that's relevant.
They were changed to 5
And I did not see a difference when I changed them
by ieatacid
Ok, I have your file now :)
Posted: August 13th, 2017, 12:50 am
ieatacid wrote: August 13th, 2017, 12:44 am My bed thermistor reads 108k ohms and the hot end reads 117k ohms. Should I use option 1?
I use option 1 and Have never had a problem.
Posted: August 13th, 2017, 12:58 am
You will need this
G code and M code master list
G code and M code master list.doc
(66 KiB) Downloaded 422 times
Original Firmware download, It would have been nice it they had the source code and not just the hex code.
https://www.hic3dprinter.com/pages/firmware
Posted: August 13th, 2017, 1:05 am
by ieatacid
With you so far.
Posted: August 13th, 2017, 1:13 am
That about it.
Except printing a 20x20mm test block, and remembering where your firmware backup can be downloaded.
Posted: August 13th, 2017, 1:15 am
by ieatacid
What programmer do I select in the Arduino IDE? And then I just build and upload it?
Posted: August 13th, 2017, 1:19 am
Arduino/Genuino Mega or Mega 2560
Processor
ATmega2560(Mega 2560)
Then of course the Port
Posted: August 13th, 2017, 1:25 am
by ieatacid
What do you have selected in the menu Tools->Programmer (below "Get Board Info")?
