Dead UM2 after short circuiting fan wires
Posted: March 16th, 2017, 4:47 pm
Hi guys,
Although I do not write here much, I still read and enjoy the forum since the very beginning.
Right now, I'm stuck with my head in a dead wall (dead UM2 wall it is) and desperately need guidance.
Full description of the problem is here, on the UM forum. A few people there tried to help, especially neotko but it looks like they too run out of the ideas.
To make the long story short.
Recently, red wire of the printhead fans became loose, so I usually just pushed it back into place. But the last time, it somehow touched probably the other, black wire, causing a small spark and instantly completely killing the printer. The board does have all the normal voltage, but the display and the printer were totally dead.
I got another board, this time v2.1.4 (the old one was 2.1.1) from Aliexpress from a seller recommended by neotko and installed it yesterday.
Now the behavior is a bit "better". PC responds to the printer being powered up and connected via USB, and Cura 15.4 can successfully perform a custom firmware update, or so it says.
However, Cura 2.4 reports that it can't see the printer.
The printer itself makes a low noise upon being powered on, with Z motor doing some clicks, like it tries to start but just can't. If that Z motor is disconnected, then another one tries to do something similar. Aside the green light on the board, another yellow one blinks.
The display is dead and the printer won't come up.
The re are some photos and a video in the thread on the UM Forum, I can put them here, too, if needed.
Tried to disconnect almost each connector and start the printer, but with the same results. I'm desperate. Anyone?
