It is supposed to be "ABS-like" although it is PLA. So I was thinking of using it for some stuff where "normal" PLA is a bit too brittle.
I have used it a bit...in fact all the black things I have posted here recently have been printed with this filament. And in general...it's nice...the pieces looks fine...it comes of the build plate easily...you can even use the "acetone finishing" on the printed models
But, i'm not that impressed with the "strength" of the pieces when you try to bend them. You can bend the pieces more easily than with "normal" PLA...but I still feel like the pieces start to break way too easily. Compared to this test i'm no way near the same result (although their test is not the most scientific...).
I just found this, which is mainly about PolyPlus...but it also mentions PolyMax...and the temperatures mentioned there are higher than what I have used so far. So far I have only printed using 200C...so i'm planning on trying higher temps to see if that makes a difference.
https://www.bcn3dtechnologies.com/en/fo ... t-working/
