What is 'HOME'-key used for ?
Posted: July 21st, 2025, 7:10 am
I never got the levelling process under my skin !
I've seen a LOT of videos on the topic levelling but with varying validity.
I dont think I've ever seen a video where the porpose of the 'HOME' key in the levelling software is explaned or even used !
I have a CR10s with Timy Machines software installed and I don't think the exact versions have any meaning here - the HOME key exist in all versions.
I'm confused on what the function of the HOME key is - if it's a:
1) SETTING of the home position of the extruding point (where the melted plastic comes out) WHEN and WHAT is this setting used for ?
2) command to the printer to GO TO the HOME-position - when or how is the HOME-position defined ?
I tend to think it's a command to GOTO the HOME-position but when I press it the extruding point is "to the center of the bed and FORCED DOWN nearly through the BED-cover - in fact it's leaving s deep hole though the cover !
To me THIS behavior seems like the printer is MISSING the SETTING of the HOME-position !
Please don't link to videos on leveling - I think I've seen them all - instead EXPLAIN then the HOME-key is used for ?
Keld from Denmark
A fairy tale country in
the north of the EU
Keld from Denmark
the north of the EU
