Tevo Little Monster stepper motor move only in one direction
Tevo brand 3D printers!
max25
3D Printer(s): Ultimaker S5
Post by max25 »
I just got a brand new TLM which I could not get running with MKS. Therefore rather than to dive deep into MKS I decided to purchase a Original Duet Wifi that arrived yesterday. After following the Tutorial on YOUTUBE " How to Install a DUET board on a Delta Style 3D Printer - The TEVO Little Monster" I was able to reach the DWC 3 and to upload the config and firmware.
However arriving at the HOME ALL "STEP", I noticed, that I do not have the Home x , y , z button only HOME ALL. After clicking HOME ALL the print head started moving very slowly with a wired noise and got stacked as the z-axis did not move and I switched of before I enter into more problems.
To find out what is going on, I followed a tutorial to check if the
different stepper motors even move. So I remove the belt and
by using G91 and G1 H2 X10 F1OO ...G1 H2 X-10 G1 H2 Y10 ....
I tried to check if the stepper motors were "moving". Well the result is for me wired noise joining the fact, that beside of a movement in only one direction for X10 and X-10 etc.. it gave
a sensation of vibration of the pulley.
I would highly appreciate any hint to come out of the sh...
If for that one need files, just ask , as I do not know
what might be needed.
For any help thank you very much.
Re: Tevo Little Monster stepper motor move only in one direction
I don't know the answer but I've seen a few mentions on that machine on Reddit
Return to “Tevo brand 3D Printers”
