UMO Travel speeds?
UMO Travel speeds?
Default is 150
I know some crank it way up...180...200 or higher
What's a good way to know if you have it just right, too low, or too high?
Dim3nsioneer
Re: UMO Travel speeds?
Post by Dim3nsioneer »
I used 250mm/s. But I have a direct drive and GT2 belts...
Titus
Post by Titus »
Using 250 too, no belts/drive updates.
It's fine if it's well adjusted and oiled :), just for dedicated prints which might fall over I use less.
I stay at 180mm/s since changed mxl to gt2. I suppose I could push it up, but since it works and works, I don't touch it.
Ofc, oil, care, and some hugs from time to time.
Hugs... :D
I was curious about that setting for a while. I pushed it up to 180 and prints some come out fine...but was always wondering what you gain going beyond that
The faster it moves from a to b, less chance of dripping in between. And ofc faster print time.
Dim3nsioneer
LePaul wrote:Hugs... :D
Neverending awe from the Ultimaker community... :-)
