Hive is a "board game" without a board. Every turn not only moves a piece but modifies the board state itself. Think chess meets dominoes!
I have available to me and Ultimaker 2 extended+, Ultimaker 2+, Ultimaker 3 Extended using Cura.
I am mostly inexperienced and had some questions about printing the following projects. Also some basic questions about what settings to use for infill density, resolution, layer height, support pattern. etc I currently use .25 layer height with 15% density, no adhesion and grid pattern...i'm not sure if there is support.
https://www.thingiverse.com/thing:3102108 How do I pick and choose which piece from the set and how do I know how many I can arrange on the plate? I'm not sure if all the machines mess up in the same place but I think some might have. It might be more efficient to print multiples of the same piece.
https://www.thingiverse.com/thing:1900248 How to cut the pieces thinner so it's mostly the piece "top identifier" and less "height"?
https://www.thingiverse.com/thing:4335705 Is it possible to invert the pieces so instead of a recess it's a plate with the "piece" sticking out?
https://www.thingiverse.com/thing:4335705 Is it possible to remove the "croptop" and make the tile straight again?
Help me print some Hive pieces?
- 3D Printer(s): Ultimaker 2 extended+, Ultimaker 2+, Ultimaker 3 E
Jump to
- Announcements
- ↳ News and Announcements
- 3D Printers
- ↳ General / RepRap Printers
- ↳ HICTOP RepRap Prusa I3
- ↳ Hardware Modifications
- ↳ General Questions
- ↳ Large Scale 3D Printers
- ↳ Tevo brand 3D Printers
- ↳ Resin 3D Printers
- ↳ Micro 3D Printers
- Ultimaker Printers
- ↳ Ultimaker S5
- ↳ General Discussion
- ↳ Special brand filaments
- Getting better prints!
- ↳ Help me fix this print!
- Software & Electronics
- ↳ Slicers and CAD Software
- ↳ Cura
- ↳ Simplify 3D
- ↳ Other Slicing programs
- ↳ Slic3r
- ↳ Electronics
- ↳ Firmware
- ↳ Firmware
- General
- ↳ Off Topics!
- ↳ The MarketPlace
- Modders Kiosk
