Let's speculate...
Let's speculate...
...since it is a quiet summer day...
When do you think we'll see the next version of the Ultimaker?
Will it have a bigger build volume?
Other features?
Other features?
Re: Let's speculate...
2 weeks?
Ah that's a popular answer
Ok week and a half
I'm hoping something larger in volume
My projects I'd like to print need bigger volume (wider and taller than Extended)
It's quite expensive to go wider than just going taller, so both probably will cost quite a bit of money.
I was wondering about a wider print area, I had a job on my hub that would have required the component being printed at a vertical and plain diagonal, which more than doubled the material due to supports.
At my wife's surgestion I looked for a printer with a larger print area, but when I looked at ones below £800 I didn't find one, although they are physically larger than the UM there print volume is smaller.
So perhaps a UM2 Wide, with a 450x225 print bed.
Oh and a laser cutter attachment.
Who's a hoopy frude, where's you towel?
And I'm supprised at you, Belg**m is the worst sware word in the known Galaxy!
And thanks for all the fish!
Well I know a few friends have bought, or have on order, the Raise3D N2 Plus
12 x 12 x 24 (inches)
304.8 x 304.8 x 609.6 (mm)
- Dim3nsioneer
1 week.
And it will have the geared feeder of the UM2+, rather more than one of them. Bundled with Cura2.2.
- drayson
1 week???
not so soon please - there I'll be on vacation...
- Meduza
I believe we will se the next version when it is released
- Dim3nsioneer
This seems obvious but it's most probably not true. If Ultimaker follows its style for announcements, we will get a picture of the new device in the almost dark first. So we will not see it when it is (going to be) released...Meduza wrote:I believe we will se the next version when it is released
