I would like to request your help in figuring out what is the issue with the following print:
. The bottom looks fine:
So an uneven bed, a tilted gantry axis, bad belt can all be ruled out, as can overextrusion and underextrusion - these issues would show in the first layers, right?
Not just the first few layers - that are printed slower - are fine, the whole section that has a lot of horizontal surface is pretty okayish, as you can see here:
It looks somewhat okay up to when the walls get 2-layer thin. I printed the same with an Ender 3 beforehand and the walls got sturdy with that one.
More system/hardware info:
- PLA
- 0.2mm (standard)
- 200 / 60 °C
- CURA slicer
- Combind is OFF
- Z-Hop on 0.125mm height, 10mm/s hop speed
- Speed 50 (standard settings)
- Filament can't be the cause
- Unchanged gantry, all fans are as they left the factory
- Retraction settings:
So that's why I'm now asking here, I would be beyond grateful for any tipps, suggestions
