Cr-6 se "Pillowing" problem?
Posted: December 30th, 2022, 6:54 pm
Hello, all! Noob to the forum here.
My printer is a cr-6 Se with an upgraded MicroSwiss hot end, and the Community Firmware. I upgraded both about a month ago, and all has been fine, until the "pillowing" started roughly two weeks ago. I'm not entirely sure it's considered pillowing, but I don't know what the issue is.
It doesn't matter what filament I use. It has happened in PLA, Silk PLA and PETG. Amongst other things, I have PID tuned, checked all belts-not too tight, not too loose, moved the z-steps up and down, leveled countless times, I have changed the infill to 100%, changed the amount of top layers from 4 to 8, changed the temperature up and down, lubed the z-rods, tightened the z-rod brass nuts and loosened them, checked the level of both z-rods, and tightened basically every structural screw on the machine. All to no avail.
I first noticed this when I left a small print alone and came back to this layer shift- I started the print again, and watched it through. When it got to the layer where it shifted, I heard a grinding noise and realized the nozzle was dragging on the font which caused the belt to skip. My initial understanding was that it was a cooling issue. So, I upgraded both the hot end fan, and the cooling fan to WinSinn 4010's with this duct -
https://www.thingiverse.com/thing:4777287 and a fan shroud for the hot end fan.
That didn't resolve the issue, so I upgraded the part cooling fan to a WinSinn 5015 with this duct - https://www.printables.com/model/157511 ... -dual-fang
Neither of those fan upgrades resolved it, so I thought I could at least resolve the layer shifting by turning on Z-Hop, and I got the print to actually finish without the layer shift. But the top layer still looks like butt. PETG (Although, pre-dehydrating. Currently in the dehydrator.) I'm at my wits end and have exhausted my (little) knowledge of what could be wrong.
So, if there's anyone out there who can suggest something, I am as appreciative as I am attentive.
