sup guys,
I want to make keychain sized skulls,animal and human heads. Would a standard resin (water/wash) be OK or will i need the extra strength
of an abs like resin? Will the standard withstand a drop to the pavement on a heavy key ring? I'll be selling these.
standard or abs like
Re: standard or abs like
I would use Elegoo ABS like resin, I use it all the time, or if you want to be 100% sure use Siraya Tech Blu, it's a bit more expensive but very very strong.
That's good to know, I have heard good things about Siraya.
I have used the Siraya Blu neat, it doesn't break, and up to 25% and 75% Elegoo ABS like, it almost unbreakable. I mix it as it's expensive to get in Spain.
Thanks fellers I'll check into the Sariya brand..
