How to make the NTC glue on ceramic heater more stable?
We try many glue but after heating, NTC still will fall off, do you have better solution?
Re: How to make the NTC glue on ceramic heater more stable?
Did you try any high temperature epoxy resins? Most of them are good for temperatures of up to 180*C or 200*C but there are also more specialized variants for temperatures of 200-280*C or even 340*C. The problem might just be to get them in super small quantities if you only need it for one bed.
