Slic3r, 'Cura' and EEPROM settings speadsheets
Discussion of the G-code generator for 3D printers
Chip Luck
Post by Chip Luck » April 22nd, 2016, 11:46 am
Just thought I would share my worksheet I use to track Slic3r, some Cura settings as I'm calibrating my machine, a HICTOP i3. It may come of use for other Slic3r and HIC i3 users, or even just those that need to record settings for any printer that uses mainly Slic3r and 'some' Cura, however you can update or change as necessary for your own use. It has helped me being fairly new at 3D printing to track my changes and keep my current settings in one place, I case I forget!
Slicer settings screenshot
EEPROM settings screenshot
HICTOPRepRapPrusaI3_Slic3r_PrintSettings_CL042216A.zip
Slic3r 'Cura' and EEPROM spreadsheet
(21.47 KiB) Downloaded 118 times
Cheers
Re: Slic3r, 'Cura' and EEPROM settings speadsheets
Post by GrueMaster » May 2nd, 2017, 12:29 am
Just found this post while poking around. ODS file format (Open Document Spreadsheet). Sweet.
Chip, you rock!
Return to “Slic3r”
