After a print, the filament retracts 15mm, but then has problems starting the next print. I looks like as it retracts the material necks, but because the filament is still hot enough to deform it forms a small collar as it retracts into the Bowden tube, which then is too large to fit back through the I2K insulator into the hot end.
The problem could be resolved if the end of print retraction was only 10mm, but I do not have the knowhow to correct it.
Any help please?
