HIC i3 - first time assembly : suggestions and mod's
Posted: March 28th, 2016, 10:00 am
LAST [EDIT] : 07.29.2016 1205 EST
Here is mine and others experience at assembly of the HICTOP Reprap Prusa i3 3D printer, for short I call it the HIC i3. After assembly, well I tore it back down and fixed all the issues that was overlooked and re-assembled the kit. Hope this helps some to not go though what we went through in our local group, we have purchase quite a few of these kits.
First, a link to actual China supplied HIC i3 printer kit here:
http://www.ebay.com/itm/HICTOP-RepRap-P ... SwXshWrz-9
They now have a newer model with filament sensor and upgraded Z-axis lead screws being offered. The lead screw upgrade is available from China for current printers for just $20 US, not bad.
Printer Assembly:
OK, now on with assembly. Assume you have the China supplied .pdf manual as you will need that,however there are some steps that are not very clear. If you are of the engineering/tech type you will figure it out. Will mention some of the main problems in the .pdf here to save you some time.
Basic tools needed for proper assembly:
o 12" digital caliper that reads in mm and inch (cheap Harbor Freight is great for this)
o square
o rigid/metal ruler in mm/inch. I have a 36" machinist ruler, again a bargain one will work fine
o oil/lube for linear bearings. I use a mixture of machine oil, a little moly grease and Teflon base Break Free lubricant
o medium thread locker. Use some type of thread locking compound on ALL nuts. I use blue Loctite, or in a pinch at least some finger nail polish
o not a tool, but patience is a true virtue here = take your time, double check everything before first run
o favorite beverage of choice
General guidelines for a new assembly:
1) Square it Up : make sure you take your time and use a level build surface. Double check especially when assembling the frame that everything is a square as possible. Tighten all the fasteners without over tightening, then pick up the frame and re-check all your measurements and again insure it is as square as possible, corner-to-corner, lengths, fit of extruded aluminum frame, t-nuts are properly seated and tightened (they are a bear to move/change later!). I finally achieved ~1mm accuracy on the frame assembly.
2) Those 5mm 't-nuts' : insure the bottom nut is properly in the channel before tightening, it can be a pain at first however I modified a flat blade screwdriver to hold the nuts in place while tightening the 5mm hex screws. Again, insure the location/fit-up of the assembly is correct BEFORE final tightening the screws or it WILL be a PITA to fix later after all is assembled, trust me on that!
3) The linear bearings and rods MUST be lubricated prior to running the machine. Failure to do that will result in pre-mature bearing failures and improper friction free axis travel!
4) A big WARNING here. If you do not use a thread locking compound on the machine screw nuts, I can guarantee you will be picking up nuts and hardware from underneath your printer after running it for a while as the supplied fasteners do not include lock washers. Main reason, wait until your end-stop switch falls off during a print, then the controller on next print crashes your axis into the hard-stop. If you are not there, expect a destroyed stepper motor and/or control board (or fire)! Again, trust me on this.
Suggested Pre-assembly Mods and Upgrades:
Due to personal experience, input from fellow HIC i3 owners and research, the following upgrades and modifications to the original China supplied parts, etc. are HIGHLY recommended PRIOR to initial assembly of this printer. Yes I know, you want to assemble it and get it up and running. Trust me, if you perform the following BEFORE you completely assemble the kit, you will save time and effort in the long run. In no particular order:
1) The OEM liner bearings will not last very long as they will start to run rough an have a severe impact on travel and print quality in the long run. I had a few ball bearings actually fall out of one of the bearing housings. Highly suggest you order a set of quality bearings from a reputable supplier. You will need 10 each LM8UU bearings. Changing these out later can be problematic!
Preform a search for: <Sprite Science⢠12 LM8UU Linear Bearings for 3D Printer>. Got 12 each from Amazon (Prime 2-day shipping) for $12.99.
2) THROW AWAY : the wire supplied to hook up the PSU output to the control board. Get you some good 12AWG stranded wire, cut to length and tinned on the ends, or you will wind up even with a proper PSU at least a 0.6volt drop at the control board. Trust me.
3) Z-axis threaded rods : well the OEM were warped, not very straight, and had all kinds of print quality issues, Z travel noise, etc. I currently have perfectly straight stainless steel rods supplied by a machinist friend and updated Z-axis motor couplers. Cannot stress how much difference this made. Specifications for the stock Z-axis rod: 300mm long x 8mm wide with a metric thread pitch of 1.25mm. You could get a printer upgrade kit from the OEM for true lead screws, followers (bearings) and updated X-axis end blocks from supplier for $20. If upgrade to lead screws the thread pitch will no longer be 1.25mm and will require you to modify your firmware (configuration.h) and re-flash the controller.
4) Power Supply : The OEM is seriously underrated. The supplied power supply (PSU) is rated 12volts @ 20 amps, this is NOT enough power to properly run this printer. As soon as pre-heat on the the bed and nozzle is performed the output on mine with stock supplied wire dropped to 9.4 volts!, you could here the X-axis fan slow down, not good if you want constant temp's on the nozzle and bed. Upgraded with a 12 volt 30 amp PSU along with using 12AWG wire, and now will full load and heat on and printing the voltage only drops to 11.92 volts. Nozzle and bed temp curves improved. NOTE: you can use the OEM supply to get your printer running, however do not expect optimum performance.
Perform a search for: "eTopxizu 12v 30a Dc Universal Regulated Switching Power Supply 360w for CCTV, Radio, Computer Project". Again, through Amazon, 2 day shipping $23.97 and money well spent.
Assembly manual clarifications:
Step 14 : will show a 'sensor' for the Y-axis. It is one of the micro-switches (end-stop switches) in the plastic bag. You will have to separate the leads as they are shipped together. Install the switch along with wires as shown in diagram. NOTE: I had wires that came off the end-stop switches and found the factory solder job was horrible. SAVE SOME TIME and re-solder all end-stop switches before installation to save to headaches later on. OF NOTE: on ALL those small 2mm (and other screws) insure you use some type of thread locking compound on those nuts, they will come loose from vibrations and your switch will fall off = not good because your stepper motor will crash the axis into the hard stop and burn up the motor or control board if you are not there when it happens. Again - trust me.
Step 23 : [EDIT] incorrect measurement shown from the rear of the lower main frame to FRONT of the RIGHT vertical Z frame. Back at step 19, it was showed the right vertical Z frame is located by measuring 165mm from the rear of the lower main frame to the REAR of the right vertical Z frame. I installed both vertical Z frames measuring as per step 19, 165mm from the rear of main frame to the REAR of both the verticals. You may try installing them both measured from the rear main frame to the FRONT as shown in Step 23 as my print center is a little forward of center, however has not been verified as the cause (fixed it in firmware). Let me know if you come up with something different.
Now, after proper assembly you are wanting to print your first object like I did, well it was a waste of filament. There are some basic print calibrations to perform first and some important software/EEPROM settings that will be required to get that print working to the best of the machines ability. These topics will summarized under the General Questions sub-forum soon.
More to come soon... again, it's a great kit for the money... just take your time and research!
Printer Assembly:
o square
