installed sensor, screen went blank
- 3D Printer(s): Ender 5 Pro
Purchased a new Geeetech A20M. Installed the 3d touch sensor, plugged it in and my display went blank. Screen will not come on at all .Easy Print will not upload the firmware to the printer. Fails to connect!!
Re: installed sensor, screen went blank
Well I had a Geeetech and the quality out of the box was awful. You might try the Facebook group, which can be helpful at times (when they aren't making excuses on the behalf of Geetech's poor quality control)
3DTouch is easy to apply as it has a small and simple structure Capturing. 3Wthings 3D Touch Smart Sensor/Auto Bed Leveling for DIY 3D Printers such as Geeetech Filament PLA 1.75 mm, 3D Printer PLA Filament, 1 kg Spool, Black . Note: 3DTouch car levelling sensor is not plug and play; you will need to do.
