Tronxy X5sa pro bed dropping when print begins
MegasXLR
- 3D Printer(s): Anycubic I3 Mega, Tronxy X5sa pro
So I have been working with 2 Anycubic I3 Mega printers with little issues, Recently decided I wanted to step up to a larger printer an was a toss between Creality CR10 v2 and the Tronxy X5sa pro. So saving a little bit of money went with the Tronxy X5sa. Finally getting a chance to work with the printer I set the Z axes then Build plate level manually and Auto. Go to do a test print an the print bed decides it wants to drop 20cm so plastic just dribbles out of extruder. The firmware is up to date and stepper motors are all good. Any help would be appreciated much thanks in advance.
Re: Tronxy X5sa pro bed dropping when print begins
Which slicer? Does it auto home correctly?
MegasXLR
Using Ultimaker Cura. Yes it homes correctly.
