Z homes move 70mm after home...
Hi I finishing tunning my third umo+ that has all the good stuff, except the board that's from china.
So my franken umo+ does home perfect but when it moves 1mm it thinks the 0 home it's at 70mm!
It's this something from um2 firmware?
I flashed it with amedee builder and esteps and all steps move perfect but it does this
Re: Z homes move 70mm after home...
Solved, connected by printrun/pronterface and got an Echo M206 that did had Z-70mm solved it by doing M206 Z0
hurray =)
Nothing like writing the stuff to find the sollution
I'm not sure what that answer is in the Queen's English....but weird for sure
To be sure, can you 'reset' NVRAM?
Ooops -- too late ;)
But I think it was the problem: some leftovers in the NVRAM...
Indeed that sounds like it. Weird I didnt knew that um2 needs a 70 offset from the endstop
Amedee wrote:To be sure, can you 'reset' NVRAM?
Hey amedee it's there anyway to read the nvram of the board to see how many hours I have used a printer? I know um2 has that, but on umo+ I never found out if was posible... Sorry just a random thought :D
It is an UM2 feature, not a Marlin Original one ;)
It is something we could relatively easily do (most probably only for SD-Card jobs as I still can't figure out how to detect properly end of USB print jobs)
That could be fun to have!
