Issues with created supports for overhangs
Posted: November 21st, 2019, 3:06 pm
I've posted this on the ultimaker community forums but I decided to give it a shot here as well.
I'm having an issue where the support structure does not print under an overhang but does print under an overhang further up the z direction. I've included some images to help show what I'm trying to explain. The model .jpg shows the areas I'm referring to. The shape and thickness of the overhangs circled in red are the same. No support structure is printed underneath the bottom overhang except, for some reason, the portion of the bottom overhang that has the hole shown in 106, 109, 110. After layer 109, Cura goes right into generating the overhang at layer 110. As you move up the z direction the support structure is printed entirely for the top overhang as shown in the sequence images 275 and 277 which result in the first layer of the overhang 279. The top overhang is fully supported. How can there be no fully generated support structure for the bottom overhang but there is for the top? I've also included the .3mf file for debugging.
