Two wires into one...minus soldering
Posted: March 7th, 2016, 10:52 am
I don't mind soldering...but I really like convenience too
Being an electronics learner...a step up from a newbie...I was thinking of using these
https://www.adafruit.com/products/1495
For the positive side block:
1. Left fan positive lead
2. Right fan positive lead
3. Positive lead to Ultimaker fan connector
For the negative side block
1. Left fan negative lead
2. Right fan negative lead
3. Negative lead to Ultimaker fan connector
Re: Two wires into one...minus soldering
Posted: March 7th, 2016, 10:59 am
by Meduza
Should work just fine
Posted: March 7th, 2016, 11:15 am
by Amedee
LePaul wrote:I don't mind soldering...but I really like convenience too
But soldering
is convenient
From this side of the ocean we would typically use Wago's for solder-less connections, but in electronics I don't like that too much.
If it needs to be disconnected frequently I would use a connector (JST or whatever), and if not, I would solder directly.
But I'm old school and these things are probably working very well
Posted: March 7th, 2016, 11:30 am
by reibuehl
I go with @Amedee - especially in environments where there is a lot of movement and vibration, nothing beats soldering. Try it, it is not that hard
Posted: March 7th, 2016, 11:32 am
Ok, so I need to figure out the best way to solder 2 wires into 1 (the two fan pos/neg into the connector wire pos/neg) !
Posted: March 7th, 2016, 11:39 am
by reibuehl
Twist the two pos/neg coming from the fans, tin them by adding a little solder. Tin the other end too. Then slide the heat shrink tube over one of the two ends and move it out of the way. Now solder both (tinned) ends together with just heat. If you tinned the two ends well, you will not need any solder here, but you can add some. Then let it cool down and slide the heat shrink tube over it and heat that one up.
