My Tevo Tornado is going Crazy
Tevo brand 3D printers!
dineroladino
3D Printer(s): Tevo Tornado
Post by dineroladino »
I am a total neophyte when it comes to 3d Printing machines. My question is, can you mess up a 3D printing by manually moving the Z axis? I believe I did something wrong while setting up my Tevo Tornado. How can I reset factory setting. My machine is grunting when I say go to Home. :-?
Re: My Tevo Tornado is going Crazy
Did you assemble it correctly?
Here's a video that might help
dineroladino
I believe I did but there is on issue. The wires I believe are mislabeled. TWO wires are labeled with an "X". Also, a couple of the wire short. They get stretched when the unit reaches it's far corners.
I am going to carefully follow instructions and see if I can get the printer going.
dineroladino wrote: May 14th, 2019, 12:24 am My question is, can you mess up a 3D printing by manually moving the Z axis?
No:
If this was the case I would never be able to print. I manually move the XY axis to pre-level the hot-bed. Then do an Auto Bed Leveling.
dineroladino wrote: May 14th, 2019, 12:24 am How can I reset factory setting.
I send a " M502 : Factory Defaults " Then a " M500 : Store Settings " to my 3D Printer to do a Reset Factory Defaults.
3D Printing is an Art or sorts It require some very mi-nute adjustments,
Can not help with the wires that are to Short wires though can help with testing the end-stops.
There is a " M119 : Endstop States " this will allow you to see if the end-stop are working correctly.
Guess I should ask do you know how to use the G an M codes.
Return to “Tevo brand 3D Printers”
