CCTREE 3D Printer Build Surface not working at all (??)
Posted: February 17th, 2019, 2:45 pm
I wanted to experiment a bit with build surfaces so I bought a set of CCTREE flexible, stick-on build surface plates. I also suspected the stock glass plate that came with my CR10S was warped so I got a pack of mirror plates from a hardware store. (They seem to be dead flat, FWIW.)
I peeled and stuck the flexible build sheet to the mirror tile, taped it firmly to the metal heat bed, and levelled it.
I have no idea what I'm doing wrong, but this stuff might as well be teflon-coated. Nothing sticks to the CCTREE plate, nothing.
I'm using PLA at ~205 degrees with the bed at ~60 to 65 degrees, and nothing sticks. The printer starts laying down lines and as soon as the printhead changes directions it pulls the just-deposited layer loose, then drags it around the print snagging the other layers and ruining the print.
Do I need to run the bed or nozzle temperature up? I've tried a few different temps on the bed and the nozzle and can't see any difference.
I don't get it- what am I doing wrong??
