PLA thickness for air pressure usage
Posted: February 12th, 2019, 5:01 am
Hi,
I’m printing an adapter using PLA to use under air pressure. This is for Airsoft (similar to paintball) and the adapter need to sustain ~100 psi. Will the PLA material handle that pressure? If yes, any recommendation on the thickness of the wall for that pressure?
If I simplify it to make easier to explain, the adapter is a 3in x 1in x 0.5in container. The air will go in from one side (0.5in side) using a quick connect and go out from the other side, thru a 5mm hole, that will have something else connected there. Basically I'm making a air pressure tank.
Is 3mm enough to handle the 100psi?
Thank you,
Mvago
Thank you,
Mvago
